Hello Guest it is October 24, 2026, 06:59:41 AM
Author Topic: Z axis moves up 2 inches after I start G code start cycle  (Read 12001 times)
« on: May 18, 2012, 11:23:23 AM »
When I Z zero my CNC using auto zero with plate and start cycle Z axis jumps 2 inches higher than normal and air cuts. When I Z zero manually by jogging to surface of material machine works as normal. I'm using mach 3 control software.
can Anyone help me with this issue?  I checked offset screen to make sure my gage block info is correct.
« Last Edit: May 18, 2012, 11:27:39 AM by dbusbee »
Re: Z axis moves up 2 inches after I start G code start cycle
« Reply #1 on: May 18, 2012, 01:24:36 PM »
I would imagine there must be something in your button code doing it. Maybe attach the code and someone may see a problem.
« Reply #2 on: May 18, 2012, 08:03:54 PM »
I have the same issue but all my axis move then once it stops I have to jog to we're I won't it then zero it then push go. I haven't had time to really try to figure it out. Let me know if you figure it out thanks.
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
« Reply #3 on: May 19, 2012, 04:17:52 AM »
It sounds as if your touch plate thickness is set at 2" thick
« Reply #4 on: May 19, 2012, 05:53:59 AM »
thanks for the replies. I checked gage block thickness and its set to .50 which is the actual thickness of block.
When I Z zero with auto zero function and then send machine to home all is well the bit rest on top of material
surface but when I start cycle bit jumps to 2 inch height then lowers to mill out height(.1250) and air cuts @
1.8750 above material
« Last Edit: May 19, 2012, 06:00:23 AM by dbusbee »
« Reply #5 on: May 19, 2012, 07:09:56 PM »
Is it using a G43 offset?
