Hello Guest it is October 24, 2026, 12:58:45 AM
Author Topic: Can you help me make 2 identical components in one sheet?  (Read 11112 times)
« on: May 17, 2012, 07:07:02 AM »
Hi
Sorry, I did say there would be many questions. ;D
I need to make a "pair" of components. Now, I realize that I can simply make one and then shift the machine zero points to another loaction on the table but is there a way I can just copy a complete component and place it next to the first one?
Using Cambam and Mach3
Many thanks if you can assist.
Al.
Re: Can you help me make 2 identical components in one sheet?
« Reply #1 on: May 17, 2012, 07:23:42 AM »
Have a look at the nesting wizard.
Offline stirling
  •  2,188 2,188
  • UK
    • www.razordance.co.uk
« Reply #2 on: May 17, 2012, 07:44:01 AM »
If you're using CAD/CAM surely you just copy and paste the part and generate the toolpath for both parts. (Sorry for calling you shirley ;D)
Ian
« Reply #3 on: May 17, 2012, 07:44:38 PM »
Why would you bother? Write the cutting part as a subroutine, use two fixtures, cut one part then change fixtures and cut again. Five minute job to code that.
Offline stirling
  •  2,188 2,188
  • UK
« Reply #4 on: May 18, 2012, 03:12:59 AM »
well the clue was in the original question
If your using CAM then it's a fair (100%) bet you're using CAD - so copy n paste - of course it depends how quick you're fingers can do a ctrl-c ctrl-v but I reckon about half a second with practice  ;D
Ian
« Last Edit: May 18, 2012, 03:18:39 AM by stirling »
