Hello Guest it is November 13, 2026, 09:36:05 AM
Author Topic: Mach 3 & Milling Spindle Control.  (Read 17970 times)
« on: January 09, 2007, 01:25:55 PM »
I am just starting to set up an Emco Mill with Mach 3 software. New stepper motors and drivers are being fitted. I intent to drive the spindle motor with a Siemens Micromaster inverter which can be set for analogue input 0-10V giving control of frequency/speed. The inverter also has a control input for an on/off switch.
I would appreciate advice on how to interface the inverter with the Mach 3 software using the PWM feature to control the spindle speed.
Re: Mach 3 & Milling Spindle Control.
« Reply #1 on: January 09, 2007, 05:58:49 PM »
I have used the spindle speed board from Bob and I know cnc4pc has one...
www.newfangledsolutions.com
www.machsupport.com
« Reply #2 on: January 10, 2007, 01:28:42 PM »
Hi Geoff,
I also have a Siemens micromaster which is going to drive the  spindle motor on a Bridgeport.
So far I have Mach3 switching the motor on/off and I can see the PWM output on the breakout board.a
I intend to use a PWM to V converter module to IP the analogue in.
Module is a Siemens Siemens Sirrius Konverter 3RF2900-0EA18.
Shame the inverters cant be configured for PWM (or does anyone know different?).
Regards
Derek.
You can "chop it off" but can't "chop it on"
« Reply #3 on: January 12, 2007, 02:06:48 AM »
Hi Derek,
Thanks for your comments. I contacted Siemens UK and asked the question. They have forwarded details of the Sirius solid state switching device. 3RF2900-OEA18
I am not clear how it would achieve what we want. It is described as follows :- "Analogue control signals are converted into a pulse width modulated digital signal. The strength of the analog input is converted into an ON and OFF swithching time within a fixed duration of 1 sec."
This appears the reverse of what we require. Am I missing something ?
Geoff
« Reply #4 on: January 12, 2007, 06:12:07 AM »
This is the circuit located somewhere on the Mach site. It will convert the 0-5v PWM to 0-10v ( Nonisolated.). Some of the new drives will accept a PWM input, either 5 or 10v, based on parameter settings.
Darek
« Reply #5 on: January 12, 2007, 12:19:49 PM »
Geoff
Hi Geoff,
I had another look at  the data sheet and you are correct !
Thanks, you have saved me a few quid.
Siemens must have a similar module though, PWM -> V
The schematic of the converter posted below looks "simple enough"
I might have a go at that if no low cost ready built modules available.
Derek.
