Hello
Guest
it is
October 21, 2026, 11:13:13 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
after tripping a limit swith, what to do about making them active again?
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: after tripping a limit swith, what to do about making them active again? (Read 11293 times)
jonny quest
233
on:
May 13, 2012, 09:49:09 PM »
I tripped a limit switch... screen pops up in mach and I hit reset on screen, them back off tripped switch, then hit flashing reset button again.
I then proceeded to home machine and it went past my trip switches.
What is the procedure for this to not happen again? It's like the limit switches were disabled.
(I did uncheck watchdog earlier in the day because it seems like people were having problem with this. I have newest version of mach... should I keep watchdog enabled?)
Carnoustie, Scotland
Re: after tripping a limit swith, what to do about making them active again?
Reply #1 on:
May 14, 2012, 05:47:02 AM »
Not really sure what you mean, especially with the first bit as it sounds like you are jogging off with the reset flashing, you cant do that so thats why I am confused, unless you are manually winding the axis off the switch?
jonny quest
233
Reply #2 on:
May 14, 2012, 09:27:16 AM »
I have to hit reset button, a Mach window pops up that says switches need to be reset, do I want Mach to do this for me.
I click yes, reset stops flashing. I then jog off tripped switch.
But after the axis is off switches, the switches are inactive.
jonny quest
233
Reply #3 on:
May 14, 2012, 12:28:40 PM »
I guess you're supposed to turn off power to machine and manually jog off limit switches?
Overloaded
4,923
Reply #4 on:
May 14, 2012, 12:43:07 PM »
Print
Pages:
1
Go Up
« previous
next »
