Hello Guest it is November 07, 2026, 03:30:30 PM
Author Topic: Constructing a Low Profile Tool Height Setter.  (Read 416643 times)
  •  9,375 9,375
Re: Constructing a Low Profile Tool Height Setter.
« Reply #20 on: May 15, 2012, 05:42:03 AM »
As always, Tweaks, your work is beautiful and so friggin clean! Love it!
Thanks Dave.
so your actual resolution and repeatability is?
Hi YNN,
That is a very difficult, if not impossible, question to answer. The difference between theoretical and actual resolution of any machine depends on just so many factors.
In practice, as you know, I do of lot of small engraving work which requires a high degree of positional accuracy but that does not necessarily mean that the work is done to a high degree of dimensional precision, after all, my machine is basically just a wood router but overall, when engraving, I expect to achieve a positional accuracy of better than ± 0.00625mm.
« Reply #21 on: May 15, 2012, 07:07:27 AM »
I've worked on grinders that can barley hold that and that's using Marposs, but then again your key word there is "expect"
Reference to your Winston Churchill signature: I expect Success but I too learn from my many Failures.  ;D
I'm just happy to get chips to fly and acceptable results. I work by thinking: Form, Fit & Function or Get out your wallet.  ;)
  •  9,375 9,375
« Reply #22 on: May 15, 2012, 08:18:51 AM »
 ;D ;D
« Reply #23 on: May 15, 2012, 08:24:16 AM »
Too cute, now if you can get that to fit and I can read it, between just two of those lines on that scale.  :o
Offline stirling
  •  2,188 2,188
  • UK
    • www.razordance.co.uk
« Reply #24 on: May 15, 2012, 08:39:15 AM »
LOL - top lines or bottom? - go on Tweakie - you can do it  ;D
Ian
« Reply #25 on: May 15, 2012, 08:52:34 AM »
That's it Ian, give that Brit a challenge.
Offline stirling
  •  2,188 2,188
  • UK
« Reply #26 on: May 15, 2012, 08:56:13 AM »
...you mean my FELLOW Brit...  ;)
Ian
  •  9,375 9,375
« Reply #27 on: May 15, 2012, 09:27:57 AM »
Ian
I know when I am beat  ;D  (but I haven't tried it using the laser yet)
Offline stirling
  •  2,188 2,188
  • UK
« Reply #28 on: May 15, 2012, 09:39:24 AM »
There's always photoshop - Doh!  ;D
  •  9,375 9,375
« Reply #29 on: May 15, 2012, 09:43:49 AM »
 ;D ;D ;D
