Hello Guest it is September 25, 2026, 11:26:17 AM
Author Topic: Rotational feedrate problem  (Read 37927 times)
Re: Rotational feedrate problem
« Reply #10 on: January 08, 2007, 07:32:42 AM »
So is it the A only moves that are the trouble ?
www.newfangledsolutions.com
www.machsupport.com
Offline rcrabb
  •  146 146
« Reply #11 on: January 08, 2007, 08:26:35 AM »
Yes, A only moves. The rotational feedrate goes to high and stalls my motors.
Ryan
« Reply #12 on: January 08, 2007, 08:30:34 AM »
Cool that will tell me where to look in the code... that is a section of code that had not been worked on in a ver long time...
www.machsupport.com
« Reply #13 on: January 08, 2007, 08:35:28 AM »
Hey Rcrabb,
     I will load it in my machine pc sometime today. Does your a axis rapid jog without missing steps? I'm not seeing it on this PC. The a axis does vary, but from what I can tell, it should because you are using the diam. for feedrate and it seems consistent with a z move.
Offline rcrabb
  •  146 146
« Reply #14 on: January 08, 2007, 08:43:13 AM »
Use the second file I posted (rotational test.nc)
Ryan
« Reply #15 on: January 08, 2007, 08:54:27 AM »
You got it.
« Reply #16 on: January 08, 2007, 09:30:22 AM »
Hey Rcrabb,
   I have sent you a PM.
« Reply #17 on: January 08, 2007, 09:57:19 AM »
Hey Ryan,
    Here is a screen shoot of the check box we talked about.
« Reply #18 on: January 08, 2007, 12:08:12 PM »
I need you to do the following...
In MDI do a G01 Z.1 A 360 F80
then do a
G01 Z1.0 A.1 F80
and last G01 A360 F80
Tell me if you get an over speed on them.
www.machsupport.com
Offline rcrabb
  •  146 146
« Reply #19 on: January 08, 2007, 01:34:14 PM »
I did your test and did not get an overspeed. I attached my XML file and a test file that has the overspeed problem. Watch the feedrate DRO when the code gets to line N400. It jumps from 20000 to about 25000.
Ryan
