Hello Guest it is November 04, 2026, 04:04:43 AM
Author Topic: Emulating G31 probe input with keyboard, should it be possible?  (Read 9440 times)
Offline ftec
  •  88 88
Hi!
Should it be possible to emulate the proble input with keyboard for G31 probing? I have done some probe related coding which I would like to simulate before running it in the machine itself. I have set the letter 'P'' (80) as the hotkey and it turns the input led on as it should but it won't stop the movement.
/Risto
Re: Emulating G31 probe input with keyboard, should it be possible?
« Reply #1 on: May 02, 2012, 10:40:24 AM »
THe g31 cannot be emulated without the driver loaded and running. SO if you are running in simualtion mode (no driver loaded) then no.
Offline ftec
  •  88 88
« Reply #2 on: May 02, 2012, 11:30:11 AM »
Right, that's it!
/Risto
