Hello Guest it is November 13, 2026, 02:41:08 PM
Author Topic: Barcode reader  (Read 24142 times)
Barcode reader
« on: April 26, 2012, 01:14:53 AM »
Hi All
Can anyone that uses a USB barcode scanner please tell me how to have Mach3 recognize it as I tried all of the com port settings in the plug in.
With thanks
Peter
Re: Barcode reader
« Reply #1 on: April 26, 2012, 02:02:56 PM »
Goto Config Plugins
Turn on the barcode plugin
Click on the config box, select the comport.  Test it while you are there. IF it does not work then recheck or set the COMPORT (general config)to match the specs on your scanner, try again.
You are using a serial Scanner right??   Does the scanner power up when pulgged in?
IF it scans in a code then you are good to go.  TO access it in mach3 from the main screen go to PLUGIN CONTROL then select load program with barcode.
Re: Barcode reader
« Reply #2 on: April 27, 2012, 03:24:55 AM »
Thanks for the reply
I am Using a USB scanner.
It powers up Ok as I can scan barcodes in notepad. but I cannot find the scanner in Mach3
Pete
Re: Barcode reader
« Reply #3 on: April 27, 2012, 03:33:39 AM »
The Plugin would seem to be for serial port only.
Re: Barcode reader
« Reply #4 on: April 27, 2012, 06:15:22 AM »
The plugin is as HOOD states SERIAL .
Re: Barcode reader
« Reply #5 on: April 27, 2012, 04:56:16 PM »
When you look in the Device Manager do you see the USB scanner  as a comport???
Re: Barcode reader
« Reply #6 on: February 14, 2013, 09:56:14 AM »
Here's a guy that says he can supply a driver with his USB readers that will create a virtural port that will be recognized by the device manager.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=281014488696&ssPageName=ADME:X:RTQ:US:1123
I like the idea of a USB reader a lot better simply because it doesn't need a separate power supply.  I'm going to give it a try.  If it works out, I'll report back.
Re: Barcode reader
« Reply #7 on: February 22, 2013, 05:02:38 PM »
Well, the virtual driver does show up in the device manager as com 4 but Mach 3 still won't use it. Sigh.
Re: Barcode reader
« Reply #8 on: February 22, 2013, 11:39:46 PM »
There is another way around the problem. Load up the scanner as it normally would beused say in word.
Press the open Gcode button when that windows pops up try using the scanner on the barcode. Thge windows window SHOULD be active on the file name box and the scanner should scan in the filename by barcode.
What barcode mode  are you using. I found that 30f9 mode worked very well and was very easy to create the barcodes.
Just a thought, (;-) TP
Re: Barcode reader
« Reply #9 on: February 27, 2013, 02:52:11 PM »
Well, I take it all back.  The virtual driver provided by that seller works just fine.
The computer I originally tried it on had been loaded down with a bunch of garbage that made it painfully slow.  I wasn't patient enough with it.
Once I tried installing it on a nice, clean machine it installed and runs just fine.
