Hello Guest it is November 13, 2026, 12:39:29 PM
Author Topic: g31 output  (Read 10797 times)
Offline jve
  •  128 128
g31 output
« on: April 16, 2012, 12:47:22 PM »
hi guys
i need to activate an out put when i call G31 or G28.1 in the g code program is this posible ?
regards
j
Re: g31 output
« Reply #1 on: April 16, 2012, 01:34:23 PM »
What exactly are you trying to do?
Offline jve
  •  128 128
Re: g31 output
« Reply #2 on: April 16, 2012, 01:50:38 PM »
i am designing a z axis that on the carage it has a punematic cylinder  so i need to call the g31 from the program and the cylinder will activate the z axis will move down find the plate suface
it is very similar to a floating head on a plasma cutter but with the difference that has a punematic cylinder
regards
j
Re: g31 output
« Reply #3 on: April 16, 2012, 03:35:43 PM »
It would be easy enough to make up a custom mcode that you could place before the G31, would that do?
