Mach Discussion => General Mach Discussion => Topic started by: jve on April 16, 2012, 01:47:22 PM
hi guys
i need to activate an out put when i call G31 or G28.1 in the g code program is this posible ?
regards
j
What exactly are you trying to do?
i am designing a z axis that on the carage it has a punematic cylinder so i need to call the g31 from the program and the cylinder will activate the z axis will move down find the plate suface
it is very similar to a floating head on a plasma cutter but with the difference that has a punematic cylinder
regards
j
It would be easy enough to make up a custom mcode that you could place before the G31, would that do?
