Hello Guest it is November 23, 2026, 07:45:14 AM
Author Topic: cant open notepad in mach 3  (Read 8862 times)
« on: April 11, 2012, 04:35:07 PM »
As the title says when I hit edit g code a small window opens (not notepad ) and then closes again and the code refreshes and that's it it worked in the  past until I tried Mach standard screen and now im back to the old one it dosnt any help please
Thanks Andrew
Offline alenz
  •  137 137
Re: cant open notepad in mach 3
« Reply #1 on: April 11, 2012, 09:57:30 PM »
You might want to check Config > General Config > Gcode Editor to make sure the path hasn’t been corrupted. The ‘Browse’ button will allow you to select/reset the path. (I like WordPad rather than Notepad for its additional features.)
Al
