Mach Discussion => General Mach Discussion => Topic started by: andrewbishop66 on April 11, 2012, 05:35:07 PM
As the title says when I hit edit g code a small window opens (not notepad ) and then closes again and the code refreshes and that's it it worked in the past until I tried Mach standard screen and now im back to the old one it dosnt any help please
Thanks Andrew
You might want to check Config > General Config > Gcode Editor to make sure the path hasn’t been corrupted. The ‘Browse’ button will allow you to select/reset the path. (I like WordPad rather than Notepad for its additional features.)
Al
