Hello
Guest
it is
November 13, 2026, 12:32:39 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Cirlce Problem
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Cirlce Problem (Read 11594 times)
dfeeney
Cirlce Problem
on:
January 05, 2007, 02:39:57 PM »
Hello everyone. New here to the forum and Mach. Just retrofitted my mill. I am having problems with any type of circle. Looks like someone drew it by hand. Not at all symmetrical. I've tried adjusting backlash, it helped somewhat. I just don't know what else to look for.
Please help.
Logged
Graham Waterworth
2,785
Yorkshire Dales, England
Re: Cirlce Problem
Reply #1 on:
January 05, 2007, 02:59:17 PM »
Poor circles are not always backlash, it could be badly adjusted slides and Gib strips, it can also be flex in the machine or tool holder.
Check all of these and correct any problems, then set up the backlash in the screws.
Graham.
Logged
Chaoticone
5,624
Precision Chaos
Re: Cirlce Problem
Reply #2 on:
January 05, 2007, 07:45:59 PM »
Also might want to check to see if your steps per are right. If you command a 1" move does it move 1"?
Logged
If you could see the things I have in my head, you would be laughing too.
Ron Ginger
925
Re: Cirlce Problem
Reply #3 on:
January 05, 2007, 07:48:54 PM »
In addition to backlash and gibs, you must also be sure your motors are tuned so that you are not loosing steps.
I had one system that used a slow processor- 600mhz I think- and it would jog any axis just fine, but it would not make circles- the extra computing to figure the path swamped the computer and the outputs got ragged and lost steps.
Logged
Print
Pages:
1
Go Up
« previous
next »
