Hello Guest it is November 13, 2026, 12:00:02 PM
Author Topic: Tool path display issue  (Read 7767 times)
« on: April 01, 2012, 12:15:09 PM »
Hey all,
I know it's Sunday so i would appriciate any and all help. I will be posting a few HELPs so many thanks to all. I have a DIY (moving table) and having a display issue. In the 'simulate program run, I can see the tool path, however in the display, I cannot see the tool moving around the tool path. How do I see this tool?
Jeff
Re: Tool path display issue
« Reply #1 on: April 01, 2012, 01:42:59 PM »
There are settings you can try from Config menu then Toolpath. The show lines from current to last will likely be one you want enabled.
