Hello Guest it is November 13, 2026, 12:14:16 PM
Author Topic: rapid rate  (Read 7660 times)
Offline jve
  •  128 128
rapid rate
« on: April 01, 2012, 04:20:23 AM »
hi guys
i have my mill which it use to have an analog potentiometer that it will regulate the rapid rate and the feed rate instant which mach3 is not making i want to ask if this is possible with mach3 cause for setting up a new job this is very usefull the problem is that mach3 is looking forward the code and when i close the rapid rate it will take a while before it will come active also on the config page there is a box (look forward gcode) and mine is set 20lines if i set this to 0 lines does this come to instant active when i close the rapid rate to 0%
