Hello Guest it is November 22, 2026, 10:03:44 PM
Author Topic: Estop unable to reset  (Read 11171 times)
« on: March 29, 2012, 09:38:07 AM »
Hii
Get an "External Estop Requested" message all the time
If I change the active level of the Estop pin I then get the "Estop Button pressed" message
Nothing seems to clear the Estop ?
Have the same problems on 2 machines my office machine with no IO connections, my CNC mill with every thing connected
I use Pokeys for its IO, could it be causing this?
Increasing the switch debounce time has no effect
Any suggestions?
Regards
Re: Estop unable to reset
« Reply #1 on: March 29, 2012, 02:25:31 PM »
If you attach your xml I will have a look and see if there is an issue in your config.
« Reply #2 on: April 10, 2012, 05:40:34 PM »
Hi
Still have 2 machines with the same problem the eternial "External Estop Requested"
Regards
Leo
« Reply #3 on: April 10, 2012, 05:58:27 PM »
Assuming you have a normally closed E-Stop switch set up to pin 11 then it should work fine.
« Reply #4 on: February 11, 2013, 02:00:37 PM »
In config setup ports and pins make sure estop is enabled
