Hello Guest it is October 01, 2026, 08:53:42 AM
Author Topic: Can Mach3 work with 2 plugins?  (Read 21301 times)
« on: March 18, 2012, 01:42:05 PM »
I have Mach 3, it is working with AJAX CNC and ethernet plugin. I do know if I can to use the parallel port.
The mach 3 is using AJAX PLUGIN. Can I work with another plugin? I need to use parallel plugin too.
Thanks in advance.
Re: Can Mach3 work with 2 plugins?
« Reply #1 on: March 19, 2012, 05:21:01 AM »
The parallel port driver is not a plugin so afraid you can not use it with the Ajax, its one or the other. If needing more non time sensitive I/O then maybe look at a PLC or the PoKeys.
« Reply #2 on: March 19, 2012, 10:37:08 AM »
How can I work with AJAX and parallel port?
« Reply #3 on: March 19, 2012, 10:47:14 AM »
You cant.
« Reply #4 on: March 19, 2012, 11:03:36 AM »
You cant.
I am needing to work with time sensitive I/O, it is for my rotary table (4 axis). It has stepper motor and driver with Enable, Direction and Step inputs. How can I do to work?
« Reply #5 on: March 19, 2012, 11:39:10 AM »
Can you not connect to the Ajax?
« Reply #6 on: March 19, 2012, 02:47:46 PM »
no, because ajax has pcb tarjet for servo motor, my rotary table has stepper motor.
« Reply #7 on: March 19, 2012, 02:49:42 PM »
Then afraid you can not use.
« Reply #8 on: March 19, 2012, 02:54:48 PM »
Do you have any idea about how I can develop or design any interface for my problem???
OR
Do you know any software engineer that he can help me?
thanks!
« Reply #9 on: March 19, 2012, 02:57:32 PM »
Easier to get a servo for the rotary axis I would think.
