Hello Guest it is November 13, 2026, 02:01:44 PM
Author Topic: Application defined or object defined error ?  (Read 10014 times)
« on: March 17, 2012, 09:28:36 PM »
Hi guys,
I was running a part and Mach threw a E-stop with an error message of "application defined or object defined error".
This was on a line with M3 S6500 command.  I changed the speed to S6000 and the code ran fine.
Any ideas?
Re: Application defined or object defined error ?
« Reply #1 on: March 19, 2012, 05:24:59 AM »
Could have been that there was no speed previously set and the M3 was being seen before the speed call.
« Reply #2 on: March 19, 2012, 08:16:18 PM »
Thanks for the repy Hood,
I went back and looked ath the code and the line read:
M3 S6500
Once changed to M3 S6000 all was fine.
I was wondering if it was a setting inside Mach that might have
looked at the speed and stopped the code.   My Max RPM setting
in the spindle setup page is 11000 RPM.
« Reply #3 on: March 20, 2012, 03:17:23 AM »
Ah ok so you kept the M3 there, I thought you meant you had removed the M3 and just put S6000.
Cant think why it would make a difference if spindle speed is 11,000 unless your spindle pulleys are set wrong but even then I would think the message would have been too fast for pulley or something like that.
