Mach Discussion => General Mach Discussion => Topic started by: kregan on March 17, 2012, 10:28:36 PM
Hi guys,
I was running a part and Mach threw a E-stop with an error message of "application defined or object defined error".
This was on a line with M3 S6500 command. I changed the speed to S6000 and the code ran fine.
Any ideas?
Could have been that there was no speed previously set and the M3 was being seen before the speed call.
Thanks for the repy Hood,
I went back and looked ath the code and the line read:
M3 S6500
Once changed to M3 S6000 all was fine.
I was wondering if it was a setting inside Mach that might have
looked at the speed and stopped the code. My Max RPM setting
in the spindle setup page is 11000 RPM.
Ah ok so you kept the M3 there, I thought you meant you had removed the M3 and just put S6000.
Cant think why it would make a difference if spindle speed is 11,000 unless your spindle pulleys are set wrong but even then I would think the message would have been too fast for pulley or something like that.
