Hello Guest it is October 22, 2026, 04:19:01 PM
Author Topic: OEMCode 84  (Read 11163 times)
dcs
OEMCode 84
« on: January 03, 2007, 01:34:15 PM »
Hi
I'm putting toghether a simple screen and I have a Jog on/off button, which does work.  I also have an LED which is tied to OEMCode 84, so it should go on/off with Jog mode, but it doesn't.  Its always off regardless of jog on/off mode.  Am I overlooking something or what??
I can post a copy of the screen when I get it done.
Offline Scott
  •  140 140
Re: OEMCode 84
« Reply #1 on: January 03, 2007, 03:58:18 PM »
Try 103 for the button and 83 for the led. 84 is the CV feed enabled led.
Check the Mach Wiki for the lists of buttons, leds, etc.  ;)
Scott
dcs
Re: OEMCode 84
« Reply #2 on: January 03, 2007, 05:34:02 PM »
Yep that did it!  ;D     I was using the list of OEM codes from a mach2 manual.
