Hello
Guest
it is
November 13, 2026, 10:43:13 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
Mach3 not loading g-code from lazycam
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Mach3 not loading g-code from lazycam (Read 9386 times)
jeffhead
9
on:
March 12, 2012, 02:26:13 PM »
Just got a new computer and I have been using mach3 for 4 or 5 yrs now. So I loaded mach3 version R3.043.022 and the lazycam that comes with it. Everything works great except when I post the g-code from lazycam it does not automatically load into mach3 I have to load it manually from the mach3 g-code folder. So my question is how do I fix this problem or is this even a problem?? Thanks for any help with this.
Overloaded
4,923
Re: Mach3 not loading g-code from lazycam
Reply #1 on:
March 12, 2012, 02:37:06 PM »
:)Hi !
4 to 5 years makes you a veteran !
Do you have this checked ?
First things first.
Russ
Reply #2 on:
March 12, 2012, 06:04:00 PM »
The only time I had the problem you described is when i did not install LC along with Mach. ie; you install Mach and then come back and install LC at later time.
What version of Windows are you using?
Print
Pages:
1
Go Up
« previous
next »
