Hello Guest it is November 13, 2026, 09:39:31 AM
Author Topic: Mach3 not loading g-code from lazycam  (Read 9385 times)
« on: March 12, 2012, 02:26:13 PM »
Just got a new computer and I have been using mach3 for 4 or 5 yrs now. So I loaded mach3 version R3.043.022 and the lazycam that comes with it. Everything works great except when I post the g-code from lazycam it does not automatically load into mach3 I have to load it manually from the mach3 g-code folder. So my question is how do I fix this problem or is this even a problem?? Thanks for any help with this.  ;D
Re: Mach3 not loading g-code from lazycam
« Reply #1 on: March 12, 2012, 02:37:06 PM »
 :)Hi !
4 to 5 years makes you a veteran !  :D
Do you have this checked ?
First things first.
Russ :)
« Reply #2 on: March 12, 2012, 06:04:00 PM »
The only time I had the problem you described is when i did not install LC along with Mach. ie; you install Mach and then come back and install LC at later time.
What version of Windows are you using?
