Hello Guest it is August 14, 2026, 06:14:03 PM
Author Topic: A dumb question I suppose..  (Read 12146 times)
« on: March 07, 2012, 02:43:49 PM »
Will the PoKeys56 MachCNC plugin v 10.6.4 (3.1.2011) work with the PoKeys55, If so how?
If not what's the solution. I can't assign any values in the Mach 3 Pokeys Config dialog
Yours Simon M.
Offline NeoTO
  •  504 504
    • PoLabs
Re: A dumb question I suppose..
« Reply #1 on: March 16, 2012, 02:20:26 AM »
A new plugin is in works by PoLabs and will be available in approximately one month.
www.poscope.com home of PoKeys USB HID, IO, USB, Ethernet controler and PoScope USB PC oscilloscope
« Reply #2 on: March 16, 2012, 03:51:43 AM »
Thanks for that I'd almost given up!
« Reply #3 on: March 18, 2012, 07:43:57 PM »
NeoTO,
     Is that the same one that Brian and I are poking at, on the SVN server? If so, there is a run time crash bug I am seeing on the Ethernet PK, But Brian says it is working with USB ok, (he test with USB, I am testing with Ether).
If you are on the SVN server, please remember to only upload code written in VS2003.
Scott
