Hello Guest it is November 11, 2026, 08:19:50 AM
Author Topic: CNC Plasma Table. 27"X62"cutting area.  (Read 9976 times)
« on: March 06, 2012, 10:37:45 PM »
I am new here and also new to the DIY CNC world. Here is a link to my you tube video showing my new table in motion. I have a 80 amp plasma that I plan on using on the table. I currently am working on the Z axis. I have the linear slide done with a 1/2-20 acme thread and support bearings. Tonight I was working on my NEMA 23 motor mount for the Z. Thinking of using a process controller from Automation direct with a 0-10 or 0-5 volt input. Then putting a voltage divider on the plasma lead. The process controller is more like a temp controller that can be set up for dual outputs for cooling and heating. It will have a PID controller built in and I can adjust the gains and thresholds to turn on the up and down relay outputs. I can also set a third relay that is set as long as the voltage is higher than say 2 volts indicating that the plasma is on.
http://www.youtube.com/watch?v=x5dhOntZdFA&feature=g-upl&context=G26a9503AUAAAAAAAAAA
  •  9,377 9,377
Re: CNC Plasma Table. 27"X62"cutting area.
« Reply #1 on: March 10, 2012, 01:52:15 AM »
Nice work Bazaro.
