Hello Guest it is November 13, 2026, 02:01:57 PM
Author Topic: OD fillet 2  (Read 32627 times)
Re: OD fillet 2
« Reply #10 on: March 04, 2012, 07:25:04 AM »
Try this,
I ran the file using your xml, using the standard screen, and code as posted from the wizard and had no problem.
Can you post a screen shot of you manual & cycle screen ?
Re: OD fillet 2
« Reply #11 on: March 04, 2012, 07:32:15 AM »
Yes ran it, heres a screenshot.
I think you may be having a version issue, are you using a development version of Mach?
Re: OD fillet 2
« Reply #12 on: March 04, 2012, 07:34:06 AM »
here they are
Re: OD fillet 2
« Reply #13 on: March 04, 2012, 07:36:11 AM »
Yes I am almost certain you have a development version loaded, they are screwed up for turn, nothing new there ;)
Re: OD fillet 2
« Reply #14 on: March 04, 2012, 07:47:03 AM »
your screenshot shows also a horizontal and a vertical line straight trough your workpiece?
Re: OD fillet 2
« Reply #15 on: March 04, 2012, 07:53:32 AM »
Not through the workpiece I dont think, that will be at the start position
The wizard is very wastefull of moves doing complete arcs of 90 degrees, the firt load of cuts will be very small but it will still move the complete 90 degrees before the next pass, only when the fillet is nearing completion will the full 90 be actually cutting.
Put a larger number for your clearance and you will get it further away, still the same wastefull moves but will look better on your screen.
Re: OD fillet 2
« Reply #16 on: March 04, 2012, 07:58:27 AM »
Still back at 3.042.033 here. Now I know why  :D
Been fooling around for the last two hours trying to screw it up and couldn't accomplish what zee.... was getting if i tried. ;D
Thanks Hood,
Re: OD fillet 2
« Reply #17 on: March 04, 2012, 08:01:08 AM »
Ok Hood, I download and installed the .....22 version and I gave it a clearence of 10mm and now it is looking good!
thanks for your help!
Re: OD fillet 2
« Reply #18 on: March 04, 2012, 08:07:43 AM »
Ok no probs, clearance of 1 would still work, just would look as if its cutting through material when its not.
Re: OD fillet 2
« Reply #19 on: March 04, 2012, 08:14:42 AM »
Hmm ...........maybe ver 059 will fix everything in lathe >:D
