Hello Guest it is November 13, 2026, 01:02:32 PM
Author Topic: Question about speeds  (Read 8129 times)
« on: March 02, 2012, 09:37:15 PM »
I'm having a bit a confusion regarding the speeds set in Mach3.
I went into the config and set the max speeds and all that good stuff, but I don't understand the relationship between that and the CAD software settings. Is the speed controlled by Mach3, the CAM software, or both?
Re: Question about speeds
« Reply #1 on: March 03, 2012, 02:21:11 AM »
Both
G0 are what you set in motor tuning as your velocity.
G1, G2 etc with a F*** will move at the F rate you have set.
