Hello
Guest
it is
November 13, 2026, 04:39:59 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
Changing FRO
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Changing FRO (Read 12611 times)
ranchak
120
Changing FRO
on:
February 29, 2012, 10:43:43 PM »
Is there a way to change the default FRO from 6IPM to something else? I know I can enter it manually, but I would like to have something like 30IPM load up every time that I start up Mach3.
Overloaded
4,923
Re: Changing FRO
Reply #1 on:
February 29, 2012, 11:48:59 PM »
You can use a little macro, put the M116 (for example) in the Initialization String. It will then set what you like when you start Mach and hit RESET.
Russ
Carnoustie, Scotland
Re: Changing FRO
Reply #2 on:
March 01, 2012, 02:18:04 AM »
Just putting F30 in the initialisation line should be enough.
Overloaded
4,923
Re: Changing FRO
Reply #3 on:
March 01, 2012, 07:25:20 AM »
....even simpler than I thought.
Thanks Hood,
Russ
ranchak
120
Re: Changing FRO
Reply #4 on:
March 01, 2012, 10:53:29 AM »
Hood, will I have to add F30 everytime I start up Mach or do I change it in my XML file?
Overloaded
4,923
Re: Changing FRO
Reply #5 on:
March 01, 2012, 11:03:28 AM »
Just put it here in the Initl. String.
It will be in effect every time you load Mach and hit reset for the first time.
Overloaded
4,923
Re: Changing FRO
Reply #6 on:
March 01, 2012, 11:04:25 AM »
it will then be saved in your XML when you shut down. Then it will always be there, unless you change it.
ranchak
120
Re: Changing FRO
Reply #7 on:
March 01, 2012, 12:06:51 PM »
Thanks that's exactly what I wanted!
Print
Pages:
1
Go Up
« previous
next »
