Hello Guest it is October 25, 2026, 10:11:29 AM
Author Topic: Changing FRO  (Read 12285 times)
Changing FRO
« on: February 29, 2012, 10:43:43 PM »
Is there a way to change the default FRO from 6IPM to something else? I know I can enter it manually, but I would like to have something like 30IPM load up every time that I start up Mach3.
Re: Changing FRO
« Reply #1 on: February 29, 2012, 11:48:59 PM »
You can use a little macro, put the M116 (for example) in the Initialization String. It will then set what you like when you start Mach and hit RESET.
Russ
Re: Changing FRO
« Reply #2 on: March 01, 2012, 02:18:04 AM »
Just putting F30 in the initialisation line should be enough.
Re: Changing FRO
« Reply #3 on: March 01, 2012, 07:25:20 AM »
....even simpler than I thought.  ::)
Thanks Hood,
Russ
Re: Changing FRO
« Reply #4 on: March 01, 2012, 10:53:29 AM »
Hood, will I have to add F30 everytime I start up Mach or do I change it in my XML file?
Re: Changing FRO
« Reply #5 on: March 01, 2012, 11:03:28 AM »
Just put it here in the Initl. String.
It will be in effect every time you load Mach and hit reset for the first time.
Re: Changing FRO
« Reply #6 on: March 01, 2012, 11:04:25 AM »
it will then be saved in your XML when you shut down. Then it will always be there, unless you change it.
Re: Changing FRO
« Reply #7 on: March 01, 2012, 12:06:51 PM »
Thanks that's exactly what I wanted!
