Hello
Guest
it is
November 13, 2026, 12:00:31 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Dynamic Trajectory Distortion
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Dynamic Trajectory Distortion (Read 12137 times)
cybercat
4
on:
February 27, 2012, 10:36:50 AM »
Hello!
I have a problem with trajectory distortions on my new router(under Mach3 indeed).
I tried to mill simple 45 degrees raster, and get unexpected result
Look at these photos. Feed on first photo 1000mm/min, on second - 10000mm/min
I'm think that reason is a acceleration patterns inconsistency between X and Y.
What can i do?
Logged
yaddatrance
13
Re: Dynamic Trajectory Distortion
Reply #1 on:
February 27, 2012, 11:51:27 AM »
It looks to me (without having seen your machine) that you're running into backlash.
Logged
cybercat
4
Reply #2 on:
February 27, 2012, 01:04:43 PM »
No, i removed all backlashes for sure
Machine -
http://www.qilicnc.net/producthtml/200.html
but with fully replaced control ( nice kit!
I forget to say that this raster 100x100mm size, so that the error exceeds 2mm!
My instance of machine is powered by Yaskawa servodrivers. May be problem is in servos, and they reaction on pulsetrain((
Logged
Carnoustie, Scotland
Reply #3 on:
February 27, 2012, 01:14:48 PM »
It would seem to be your servo tuning is the issue, as you suspect.
Logged
cybercat
4
Reply #4 on:
February 28, 2012, 01:33:16 PM »
I can't imagine what exactly was а source of problem, but i fix it.
Thank god, servodriver has pulse filtering function, which brings time delay in input pulsetrain.
When i added some delay in Y axis pulses, lines in trajectory become straight.
Logged
Reply #5 on:
February 28, 2012, 01:55:34 PM »
Not really sure what setting that may be but as long as its working thats all that matters
Logged
Print
Pages:
1
Go Up
« previous
next »
