Hello Guest it is October 21, 2026, 10:35:07 AM
Author Topic: Operating a punch machine via Mach3  (Read 14113 times)
« on: February 20, 2012, 04:37:48 AM »
I recently bought a CNC punch/nibble machine (Swedisch Pullmax P 210 dcm) The machine is 25 years old and is controlled by a TRS80 like homecomputer with Z80A processor. Working: The(steady)  tool of the machine punches little holes and by moving the table it can cut out figures out of sheetmetal or aluminium.  I would like to replace the Z80A computer by a Mach3 solution. I don’t see many problems by taking over the control over the X and Y axes.  But the punching tool is another issue. My question is: Is this done before and how do I control the punching movement?  I read in a manual about PWM Motor Control but I am not sure if this is a solution.
Re: Operating a punch machine via Mach3
« Reply #1 on: February 20, 2012, 05:34:33 AM »
How is the punch controlled?
« Reply #2 on: February 20, 2012, 08:40:53 AM »
Hood,
I don't know (yet). The machine arrives in a few weeks time. I have a wiring diagram that shows de X and Y axes. The are operated bij stepper motors with a choppermechanism to reduce the current. The punch is simple, you have to change the tools by hand. The only thing it does is move down and up. From once to 100 times or more/minute.
Do you know if there are different kinds of motorsolutions for the punch head and how does that influence the software?
Wim
« Reply #3 on: February 20, 2012, 09:24:38 AM »
Dont know anything about punches but when you get it and find out how it works then maybe a solution can be found.
« Reply #4 on: February 21, 2012, 04:22:17 PM »
The last Pullmax I saw has an air punch.  Worked kind of like a planishing hammer.  They were using it to form louvers.
« Reply #5 on: June 24, 2013, 03:21:23 PM »
greeting
Are you able to insert the machine for breaking run with MACH3 I have the same one to do if your doing the experiences
