Hello Guest it is November 13, 2026, 10:03:07 PM
Author Topic: New End Groove Wizard, along with my old Parabola and tapers upto a Face  (Read 10191 times)
Offline zarzul
  •  233 233
  • Wyoming, USA
Hi All,
Just finished my new end groove wizard and thought I would post it to share with you all.  I was very motivated, I needed to cut o-ring grooves in the ends of my dive light housing I am working on.
To use it you just unzip it and put it in a subdirectory under the TurnAddons folder,  I named mine MY TURN,  make sure the bitmaps folder is a sub folder of MY TURN, and your ready to go.
An alternate way, which is how I am doing it, is to use screentweek and append the screens from MY TURN into the fine turn wizards Brian & Kiran made, then go add your buttons on the menu page to select the correct wizard.
The first download is the zipped MY TURN wizard,  also attached is a picture of the dive light head with the oring groove cut into the end.
Re: New End Groove Wizard, along with my old Parabola and tapers upto a Face
« Reply #1 on: January 01, 2007, 01:11:32 PM »
Thank you for your work! Love to see people use the power that we have given to you!
www.newfangledsolutions.com
www.machsupport.com
