Mach Discussion => VB and the development of wizards => Topic started by: zarzul on January 01, 2007, 12:26:51 PM
Hi All,
Just finished my new end groove wizard and thought I would post it to share with you all. I was very motivated, I needed to cut o-ring grooves in the ends of my dive light housing I am working on.
To use it you just unzip it and put it in a subdirectory under the TurnAddons folder, I named mine MY TURN, make sure the bitmaps folder is a sub folder of MY TURN, and your ready to go.
An alternate way, which is how I am doing it, is to use screentweek and append the screens from MY TURN into the fine turn wizards Brian & Kiran made, then go add your buttons on the menu page to select the correct wizard.
The first download is the zipped MY TURN wizard, also attached is a picture of the dive light head with the oring groove cut into the end.
Thank you for your work! Love to see people use the power that we have given to you!
