Hello Guest it is November 13, 2026, 10:01:46 AM
Author Topic: Testing a stepping motor  (Read 8923 times)
« on: February 19, 2012, 01:24:17 PM »
I bought a kit with power supply, TB6560 driver board and 3 steppers on eBay. I want to test the electronics out, but the router isn't finished yet.
Can I hook everything up and test run a stepper on the bench? If so how do I go about doing it.
brianglo
Re: Testing a stepping motor
« Reply #1 on: February 19, 2012, 02:58:07 PM »
Yes just connect as you would if it was connected to the router, set up Mach and jog or MDI or run code in Mach.
