Hello
Guest
it is
November 01, 2026, 01:44:06 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Toolpath Highlight
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Toolpath Highlight (Read 8761 times)
dfurlano
252
Toolpath Highlight
on:
February 17, 2012, 05:21:04 PM »
Isn't there a way to have the path highlight as you scroll through the gcode in the toolpath window. i look for settings but could not find anything. Thought I did it before but it was a long time ago.
TIA
Logged
Overloaded
4,923
Re: Toolpath Highlight
Reply #1 on:
February 17, 2012, 09:26:21 PM »
Similar to this ?
http://www.machsupport.com/forum/index.php/topic,20791.0.html
Logged
Overloaded
4,923
Reply #2 on:
February 17, 2012, 09:30:39 PM »
You can also select "Lines from Last to Current" under Config / ToolPath.
This will keep lines highlighted when running the part program.
Russ
Logged
Print
Pages:
1
Go Up
« previous
next »
