Hello Guest it is November 12, 2026, 06:46:50 AM
Author Topic: Program run problem with motors and DMC2030  (Read 9204 times)
« on: February 17, 2012, 11:48:00 AM »
I am now having a problem with the motors running very roughly when I run a program but when jogging they work just fine. I have tried the max speed from 30 - 120 and it seems to make no difference on roughness of the motors. I can go to WSDK and move slow or fast from the terminal and they are perfect. This problem shows up only when Mach moves the motors with a G command. I have checked the plugin parameters and they are set where the tutorial recommends. Am I missing something?
