Hello Guest it is November 01, 2026, 01:44:25 PM
Author Topic: Flat spot on circles  (Read 9401 times)
« on: February 12, 2012, 05:24:25 AM »
I have a problem when cutting circles about 25mm in diameter.
The problem is the circle has a small flat spot on one side.
I have tried slightly different size circles 20mm & 30mm and it appears on all of them.
I am using VCarvePro to generate my G Code to a Proxxon MF70 CNC controlled by Mach3.
Not sure whats causing it so any help is appreciated.
Jason
Offline Hal
  •  60 60
Re: Flat spot on circles
« Reply #1 on: February 12, 2012, 08:08:24 AM »
Check youp backlash. You may have a little more in that area of your table. The extreme would be some pitch error in your lead screw.
Hal
« Reply #2 on: February 12, 2012, 04:36:58 PM »
Thanks for the reply Hal.
I'll check for backlash and see if that cures it.
Jason
