Hello Guest it is November 22, 2026, 06:31:02 AM
Author Topic: Limit/home switch setup problems.  (Read 10373 times)
« on: February 09, 2012, 07:26:21 AM »
Hello everybody.
I'm still a noob, even though I have owned the program for almost 3 years now...
I want to setup my home and limit switches on the same pins on my BOB. The setup is no problem, but the functions of the switches is a bit more tricky I have leraned.
I need a script of some sort that will allow me to move the machine manually if the machine hits a limit switch.
But after trying numerous things I have come up short.
I have heard however that a script which tells mach3 what to do if a limit switch is triggered is the only way to go.
I have searched this forum alot, and have yet to find anything regarding this. Is there someone who can point me in the right direction?? I'm at a loss here... :(
Re: Limit/home switch setup problems.
« Reply #1 on: February 09, 2012, 07:36:00 AM »
 :) ... it's all in the book.
« Reply #2 on: February 09, 2012, 07:40:37 AM »
Damn.... Am I stupid or what... :p
Thank you very much, just what I needed... :)
When in need of things, then the books usually offer more than you think... !!! :D
« Reply #3 on: February 09, 2012, 07:46:03 AM »
 :) No, not at all. This is one that is frequently overlooked and commonly asked about.
Be sure to download the manuals under SUPPORT above.
A quick glance at the INDEX will usually take you exactly where you need to be.
Have fun and be careful.
Russ
