Hello Guest it is November 22, 2026, 07:02:12 AM
Author Topic: saving setup  (Read 10123 times)
saving setup
« on: February 08, 2012, 10:16:03 PM »
Just downloaded the new version of Mach, how do I save my old setup (ports and pins, motor tuning info) and move it to the newer version?
Thanks in advance for any help
Re: saving setup
« Reply #1 on: February 09, 2012, 06:06:07 AM »
see here
http://www.machsupport.com/forum/index.php/topic,20778.msg144645.html#msg144645
That is for backup just in case something goes wrong.
Re: saving setup
« Reply #2 on: February 09, 2012, 05:33:49 PM »
That will help but I updated to the newest version and now I have 2 different versions on my desktop, how do I get the settings from the old one into the new one? am I just deleting these same files in the new version and replacing them with the ones I copied from the older version?
Re: saving setup
« Reply #3 on: February 09, 2012, 05:40:21 PM »
You must have installed the newer version of Mach to a different location that your previous version. Anyway no need to delete as when you paste or drag them into the new folder Windows will just ask if you want to replace and if you say yes it will.
