Hello Guest it is November 13, 2026, 12:18:20 PM
Author Topic: Motion abnormalities  (Read 10837 times)
« on: February 05, 2012, 09:28:33 PM »
In the use mach3 control 4 axis engraving and milling machine, Yaskawa servo motor sports, motor frustrated phenomenon is what causes?
Re: Motion abnormalities
« Reply #1 on: February 06, 2012, 01:47:16 AM »
Not a clue what you are asking I am afraid, you will need to try and explain what your problem is.
« Reply #2 on: February 06, 2012, 01:56:51 AM »
MACH3 which set the maximum speed of the servo motor is 3000mm/min the acceleration 1500mm/ss finish roughing code, finishing code motor frustrated phenomenon, the movement is not smooth.
« Reply #3 on: February 06, 2012, 01:57:43 AM »
« Reply #4 on: February 06, 2012, 03:47:13 AM »
Not much to go on and really still not sure what you are meaning but my guess would be that your issue may be the servo tuning in your drive.
