Hello Guest it is November 13, 2026, 09:50:37 AM
Author Topic: G-Code Cut or Missing When opening in Mach3  (Read 15244 times)
« on: February 05, 2012, 07:09:43 PM »
Hey all, so i tried to do my 1st 3D cut.... well it didn't work to well what i found out that when I loaded G-code generated from MeshCam, Mach3 only took some few lines of the code and ignored rest of the file... How acn this be fixed?
Attached what i got: 1st i loaded full file with rough and fine finishj but only gut what you see on top: section of rough finish which is not even close to sphere shaped taht i was cutting. Then i loaded lust fine finish and got only that deep hole that supposed to be full sphere.
So the question is: how can i fix that? TNX!
Re: G-Code Cut or Missing When opening in Mach3
« Reply #1 on: February 05, 2012, 09:02:47 PM »
Sounds like you have an unlicensed copy of Mach3, which only allows 500 lines of code.
« Reply #2 on: February 05, 2012, 09:04:20 PM »
strange... i should have license, unless guy who sold me machine cheated on me...
How can i check the license status?
« Reply #3 on: February 05, 2012, 09:19:01 PM »
Your name should be displayed in the title bar, if it's a recent version of Mach3.
« Reply #4 on: February 05, 2012, 09:28:57 PM »
it does  ::)
i did hoeever install the update, the machine came with older version of Mac3 like few digits older so i installed new one over it. Could it be a problem? Can I reset license some how or diagnose the problem?
« Reply #5 on: February 05, 2012, 09:30:29 PM »
The code looks OK here, it loads and runs fine.
If you bought a used machine, Mach3 licenses are not transferable. If you bought a new machine which came with a license, it should come from Artsoft, so it contains your name.
« Reply #6 on: February 05, 2012, 09:39:12 PM »
i bought new machine and it has my name...
Should i reinstall the software or buy new license separately?
« Reply #7 on: February 05, 2012, 09:51:10 PM »
ok never mind... i rebooted machine and now file shows up ok and in fulll.... pitty though that i least coordinates so will need to redo test part again
