Hello Guest it is November 22, 2026, 02:43:08 PM
Author Topic: Digitizing wizard results  (Read 21995 times)
Offline IBBruin
  •  13 13
  • Poppa D
« on: February 01, 2012, 05:56:08 AM »
I have a question about the file generated by using the digitizing wizard in Mach. When I open the file that's generated during my probe it only has a list of numbers like this:
1.487484,2.465796,6.346739
1.567484,2.402796,6.334739
1.387484,2.775796,6.395654
1.569484,2.465796,6.391239
These are not the exact numbers but this is the format stored in the file. I understand these are xyz coordinates generated during the probe but there are no G-M codes or feed rates, just numbers. Am I going to have to edit and put in my own codes or did I miss a step somewhere?
Re: Digitizing wizard results
« Reply #1 on: February 01, 2012, 06:10:05 AM »
Put a check here, in Ports n pins / Mill options.
Russ
Offline IBBruin
  •  13 13
  • Poppa D
« Reply #2 on: February 01, 2012, 06:13:21 AM »
Thanks for the quick response. I'll be on the road for a few days so I won't get a chance to do that probably until the weekend.
« Reply #3 on: February 01, 2012, 06:18:50 AM »
You're very welcome.
Be sure to let us know how it goes.
Russ
Offline IBBruin
  •  13 13
  • Poppa D
« Reply #4 on: February 01, 2012, 06:40:44 AM »
I'm just thinking out loud now and I'll get my answer sometime this weekend but... with the resulting gcode using the digitizing wizard, when I go to cut my material, will up be up, over, down, up, over, down like the probe or will it cut like a 2.5D?
« Reply #5 on: February 01, 2012, 06:50:53 AM »
Not up, over, dn ....point to point.
Offline stirling
  •  2,188 2,188
  • UK
    • www.razordance.co.uk
« Reply #6 on: February 01, 2012, 06:53:09 AM »
Russ - doesn't your option just add in X,Y and Z i.e. it doesn't add in any G commands so in answer to IB's last question - neither?
Ian
« Reply #7 on: February 01, 2012, 07:01:27 AM »
Hi Ian, afaik, after setting up and running the wizard at it's specified feed rate, the file is created point to point as in the example shot.
Then you'd have to select a cutter and insert the associated settings for machining. Feedrates and such.
Only used it a couple of times.
Hope I'm understanding your question.
Russ
« Reply #8 on: February 01, 2012, 07:21:01 AM »
Hi Ian, here is the file created from the above illustration.
All I added is marked, it just rolls along point to point, not up/over/dn as when digitizing.
G17 G40 G90 G64 G20 G50 (Normal Preamble ADDED)
G1 F30 (ADDED)
x0.00000 y0.00000 z-0.37300 a0.00000
x1.00000 y0.00000 z-0.35900 a0.00000
x2.00000 y0.00000 z-0.08200 a0.00000
x3.00000 y0.00000 z0.07300 a0.00000
x4.00000 y0.00000 z-0.03100 a0.00000
x4.00000 y1.00000 z-0.30700 a0.00000
x3.00000 y1.00000 z0.00600 a0.00000
x2.00000 y1.00000 z0.34200 a0.00000
x1.00000 y1.00000 z0.15100 a0.00000
x0.00000 y1.00000 z-0.26800 a0.00000
x0.00000 y2.00000 z-0.18500 a0.00000
x1.00000 y2.00000 z0.22600 a0.00000
x2.00000 y2.00000 z-0.67300 a0.00000
x3.00000 y2.00000 z-0.21700 a0.00000
x4.00000 y2.00000 z0.65100 a0.00000
x4.00000 y3.00000 z0.26300 a0.00000
x3.00000 y3.00000 z-0.19400 a0.00000
x2.00000 y3.00000 z0.09200 a0.00000
x1.00000 y3.00000 z0.19100 a0.00000
x0.00000 y3.00000 z-0.60600 a0.00000
x0.00000 y4.00000 z0.27300 a0.00000
x1.00000 y4.00000 z0.06500 a0.00000
x2.00000 y4.00000 z-0.14500 a0.00000
x3.00000 y4.00000 z0.48800 a0.00000
x4.00000 y4.00000 z0.00600 a0.00000
M30 (ADDED)
Offline IBBruin
  •  13 13
  • Poppa D
« Reply #9 on: February 01, 2012, 07:25:37 AM »
Thanks Russ, that's exactly what i was looking for. I only know enough gcode to send my tool deep into my table.
Darryl
