Hello Guest it is November 22, 2026, 02:32:07 PM
Author Topic: Digitizing wizard results  (Read 21988 times)
Offline stirling
  •  2,188 2,188
  • UK
    • www.razordance.co.uk
Re: Digitizing wizard results
« Reply #10 on: February 01, 2012, 07:35:46 AM »
Thanks Russ. Just a thought Darryl - "normally" you'd take the wizard output file and use it in a CAD package to create a model of your original object. You'd then use CAD to produce a toolpath. If you want to skip these steps you need to cut with a ballnose that's pretty much the same size as your probe tip. Sorry if I'm stating the bl**ding obvious  ;D
Ian
Offline IBBruin
  •  13 13
  • Poppa D
« Reply #11 on: February 01, 2012, 07:42:07 AM »
You're not stating the obvious to me. I'm new to all this. I built a probe and dying to try it out.
http://www.cnczone.com/forums/diy-cnc_router_table_machines/146212-free_plans_my_digitizing_probe.html
