Hello Guest it is November 13, 2026, 03:03:18 PM
Author Topic: Spindle stopped working, help!  (Read 19916 times)
« on: February 01, 2012, 01:49:46 AM »
Hi guys,
I have a very strange problem here. I was running my CNC machine this morning and it was running fine. I turned it off for about 4 hours and when I came back and tried to run a cut the spindle would simply not work at all. all the axis move perfectly and I even plugged the spindle directly to check if it's running and it's fine, but it's not running from mach, either if I try to make it run or if I run a program.
Can someone help me please?
Re: Spindle stopped working, help!
« Reply #1 on: February 01, 2012, 03:42:45 AM »
does the yellow light flash on the screen, when you activate the spindle
« Reply #2 on: February 01, 2012, 05:01:01 AM »
Yes, it flashes like if it was running normally but the router doesn't start. I checked the config a couple of times, turned off and on the machine and pc and still same problem.
What can I do?
« Reply #3 on: February 01, 2012, 05:07:42 AM »
what powers the spindle
« Reply #4 on: February 01, 2012, 05:28:01 AM »
The Cnc has a control box which is connected to the pc but it only has the on/off buton
« Reply #5 on: February 01, 2012, 05:33:38 AM »
is there a seperate fuse in the control box for the spindle?
Does the spindle have speed control?
« Reply #6 on: February 01, 2012, 05:41:27 AM »
You can change the speed but only trough mach3 and I even tried to increase it to the max or min and nothing happens. It's actually the only part that is not responding, all the axis move perfectly
« Reply #7 on: February 01, 2012, 05:57:03 AM »
ok, there are normally two functions required to run the spindle.
1. A relay will be energised to enable the spindle.
2. a signal is sent to an analogue board to vary the speed.
start the spindle in mach and listen for the relay activation.
« Reply #8 on: February 01, 2012, 06:07:01 AM »
You really need to get in the control box to see what type of spindle controller you have. A pic of the insides will help.
« Reply #9 on: February 01, 2012, 02:21:56 PM »
I opened the control box, but the machine is practically new! less than a month old! so everything looks very new.
this is my machine
http://i00.i.aliimg.com/img/pb/566/899/410/410899566_149.jpg
this is the box from behind
http://i01.i.aliimg.com/img/pb/711/297/396/396297711_781.jpg
and the box inside
http://alejooz.blogspot.com.au/2012/02/blog-post.html
