Hello Guest it is November 13, 2026, 10:02:12 AM
Author Topic: Small hobby CNC routers  (Read 25496 times)
« on: December 29, 2006, 05:00:33 PM »
Hi
I have recently finished the building stage of what I hope will be my home workshop CNC router table. The table has a cutting area of 37 x 25 inches and is built to the plans in David Steele's book "CNC Router Plans (plans for inexpensive cnc router tables)".
I have purchased a package from Xylotex which includes 269 oz in steppers, driver and power supply and have downloaded Mach 2 as an operating system.
I now find myself at somewhat of a loss as to what to do next.
Is there anyone that has built a table from these plans and is running similar motors etc. that can assist with the setting up and wiring required to get this thing actually cutting stuff???
I am a newcommer to the world of cnc, I know little about cnc machinery and even less about the Mach 2 software.
Many thanks
Lawrie
« Last Edit: December 29, 2006, 05:04:36 PM by vistabeads »
Re: Small hobby CNC routers
« Reply #1 on: December 29, 2006, 07:00:52 PM »
Why didn't you go with Mach 3, latest version? We will help what we can.
« Reply #2 on: December 29, 2006, 10:16:52 PM »
There are many people here that have done the same thing and will be a great help :) I will try to help as well  8)
www.newfangledsolutions.com
www.machsupport.com
« Reply #3 on: December 30, 2006, 02:09:28 PM »
Thanks guys
Having downloaded and licenced Mach2 can I now download Mach3 and use it under the same licence? If so which version would you recommend?
Lawrie
« Last Edit: December 30, 2006, 02:21:02 PM by vistabeads »
« Reply #4 on: December 30, 2006, 04:48:33 PM »
Use Mach3 :)
I can't setup mach2 anymore :(
www.machsupport.com
« Reply #5 on: December 30, 2006, 07:09:59 PM »
Hey Lawrie,
     I would go with Mach 3 version 2.0.030. It is the latest. The licenses for Mach 2 will work with Mach 3.
« Reply #6 on: December 30, 2006, 08:09:07 PM »
Thanks for that Brett, I have now changed to Mach 3
« Reply #7 on: December 30, 2006, 08:13:30 PM »
Your welcome, we will help get you going. You will be fine. You may want to check out the tutors and documents. They will help clear up a lot of questions. Check out the tutorials tab at the top of this page.
rukamani
« Reply #8 on: December 30, 2006, 08:40:36 PM »
gr8 then help me also
« Reply #9 on: December 30, 2006, 08:48:22 PM »
We will if we can. Put up a post of your problem.
