Hello Guest it is October 20, 2026, 09:44:15 PM
Author Topic: set up for hot wire foam cutting please  (Read 50720 times)
Re: set up for hot wire foam cutting please
« Reply #30 on: March 19, 2012, 05:54:09 AM »
TB drives can work ok or not, they can be poor quality or slightly better quality and I believe they require a wider pulse and of 5v rather than 3.3v.
Jog keys jog an axis and thats all.
« Reply #31 on: March 29, 2012, 06:40:38 PM »
hi can anybody help if my carrages are say 300mm away from the home switches they return slow then speed up just before the home switches and hit a little to hard how do i adjust them and reverse them so they return faster them slow down before they touch the home switches
many thanks mark
« Reply #32 on: March 30, 2012, 04:08:13 AM »
How are you sending home? Is it a button or is it a G28.1from code or?  If a button what is the code in the button?
« Reply #33 on: March 30, 2012, 03:18:51 PM »
hi hood hope you are well
i am using g28 to move away from home switches to a comfortable area ie center of rails  now i hit ref all home on program run screen
i can cut retangles now but getting stuck on ribs i am not sure if i am using the wrong type of line to draw
hood if you get a chance could you please look at this file it is for a wing section but when i load it it look fine on screen but the 4 axis hot wire machine makes it off set ie where the wing spars would the back of the wing section drops by about 6-8 mm top and bottom
cheers mate          marky
« Reply #34 on: April 09, 2012, 11:35:52 AM »
hi all thanks for all help recieved
i have found if i switch off the backlash  my machine cuts the right shape ie a wing profile but now the garrages go to home switches but do not come back off of them
i have looked at the soft max, soft min,slow zone and home off to sort out my problem lol to be honest i dont know what to look for or do
may thanks marky
STEPPER MOTOR STALLING
« Reply #35 on: April 09, 2012, 11:51:39 AM »
i got a questioN.
why my cnc router when is cutting the motor is ramdon stop moving, especially in arc , curve sometimes lines too, IS THIS A STALLING?
MY SET UP
nema 34 motor
microstepping current set  peak 5.7 amp   rms = 4.0 amp
micros stepping  set  1600 = 1/8
lead screw is 10 tpi
motor tunning
step per      velocity inch or mm p min   acceleration inch or mm/sec
16000               40                                        10
 by the way i got one power supply for each stepper motor
 power supply information
 ( 3 POWER SUPPLIES ) =
 48V  7.5A  360W DC Regulated Switching Power Supply
I HOPE YOU CAN HELP ME THANKS
DO YOU KNOW IT THE COMPUTER PARALLEL PORT  HAS TO BE 3.3 VOLT OR 5.0 VOLT BEACUSE MINE HAS 3.3 VOLT OUT
