Hello Guest it is November 13, 2026, 12:56:45 PM
Author Topic: Z home goes past 0.0 to +1.0  (Read 82367 times)
Offline ttm
  •  40 40
  • Learning my first CNC router plasma setup
Re: Z home goes past 0.0 to +1.0
« Reply #10 on: January 27, 2012, 04:51:32 PM »
like Hood says, need to see that screen.
Is there a "Home Off" value set for the Z in Homing/Limits ?
under motor home/soft limits? no there is not
Thank you!
No there is not
« Reply #11 on: January 27, 2012, 05:59:37 PM »
ttm,
Can you post a screen shot of the screen your using as requested?
« Reply #12 on: January 27, 2012, 06:20:25 PM »
OK first you have to realize that Home and zero can be 2 different things.
If you are just moving to a location and press zero you are just resetting the local Zero position. That has nothing to do with HOME wich is a machine reference position Machine Zero.
IF you do not have home switches then Mach set HOME to whatever is current WHEN you first fired up Mach3. It just happend to be at +1.00 when you did it. IF you can find a button called RefHome it will reset the machine Zero.
There IS a proceedure for setting Machine Zero( HOME) without a home switch.
I take it that this is a plasma rig ??? and you are using the CandCNC stuff????
« Reply #13 on: January 27, 2012, 06:25:11 PM »
Based on another post he made, I believe it is a CandCNC screenset.
Offline ttm
  •  40 40
« Reply #14 on: January 27, 2012, 06:25:24 PM »
ttm,
I'll give it a try
Offline ttm
  •  40 40
« Reply #15 on: January 27, 2012, 06:32:37 PM »
iok, I do keep getting home reference mixed up, let me explain what is happeningbetter
when I have played with this before, I could move the axis to a position, then zero x, y and z axis, I could move the axis anywhere on the table, then hit home and it would take it back to that location I had zeroed out, it will still do x and y, but Z will lower right past zero and go +1.0 further, then stop.
never hitting any limit switches, or home switches, which I have yet to get working.
yes, this is a candcnc unit, -plaspakIII mp3000 ubobII DHTC, servo motors, I do not have the torch on it right now, I am trying to learn how to run it until I get that part repaired, as I want to convert it to router as needed , so right now I am working without the thc sensor on the machine
I am and have been pretty confused about this
thank you very much
Offline ttm
  •  40 40
« Reply #16 on: January 27, 2012, 06:38:18 PM »
here it is
Offline ttm
  •  40 40
« Reply #17 on: January 27, 2012, 06:39:33 PM »
here it is
another thing is, I never have seen a slow soft linmit work
oops thank you!
Offline ttm
  •  40 40
« Reply #18 on: January 27, 2012, 07:25:32 PM »
ttm,
got it up rich a few posts down
thank you for looking
http://www.machsupport.com/forum/index.php?action=dlattach;topic=20696.0;attach=29277
« Reply #19 on: January 27, 2012, 09:35:11 PM »
Is this it ?  ::)
« Last Edit: January 27, 2012, 09:47:13 PM by Overloaded »
