Hello Guest it is October 21, 2026, 09:46:29 AM
Author Topic: accel and velocity  (Read 72402 times)
Re: accel and velocity
« Reply #50 on: March 05, 2012, 06:11:05 PM »
I have been trying to calibrate steps per unit using mach 3 settings and checking with digital readout.  Not consistent.  It will be off. 018 going in positive direction and. 786 in negative direction.
Sent from my DROIDX using Tapatalk
« Reply #51 on: March 05, 2012, 06:11:39 PM »
Those numbers are off using 10 inches of travel
« Reply #52 on: March 06, 2012, 12:54:35 AM »
Calculate the steps per unit from your hardware specs.
« Reply #53 on: March 06, 2012, 09:11:27 PM »
I will set x and y to 20000 and z to 22222.2222 . Then hopefully adjust settings until its accurate.  This will fix the problem of traveling different in positive and negative directions?
« Reply #54 on: March 12, 2012, 07:54:51 PM »
It is set at 20000 steps per unit. It is consistently travelling .990 in one direction and 1.06 in the other.
Offline alenz
  •  137 137
« Reply #55 on: March 12, 2012, 09:21:09 PM »
As Hood stated your hardware specs determine the correct step/unit, other methods are approximations subject to the accuracy of your measurements. You might want to take a look at a stepper calculator http://www.machsupport.com/forum/index.php/topic,16315.0.html
 to verify/confirm your calcs.
Also are you allowing for backlash in your measurements? Backlash could account for what you are seeing.
al
« Reply #56 on: March 13, 2012, 07:33:29 AM »
Im using a digital readout for the travel measurements
« Reply #57 on: March 14, 2012, 07:31:00 PM »
I got the steps per unit correct in the settings. I entered 3 inch moves and it was correct with the digital readout. But when I went to mdi and entered a motion it over traveled again. Feeling like its never going to be right to be honest.
« Reply #58 on: March 15, 2012, 08:37:25 PM »
Now its moving correct with straight cuts but not angles or arcs. I need help PLEASE. I have to get this fixed and im learning as I go.
Offline Fastest1
  •  920 920
  • Houston, TX
accel and velocity
« Reply #59 on: September 16, 2012, 08:49:11 AM »
You never answered in regards to backlash. After you got your distances traveled correct did you measure for backlash? Do you have it entered and enabled? What % is your arc slow down set to? Do you have CV or Exact Stop selected?
