Hello Guest it is October 20, 2026, 09:44:41 PM
Author Topic: accel and velocity  (Read 72370 times)
Re: accel and velocity
« Reply #30 on: February 06, 2012, 04:20:53 PM »
I will check into the dugong gearing
Sent from my DROIDX using Tapatalk
« Reply #31 on: February 06, 2012, 11:51:45 PM »
Just curious. Are you guys self employed machinists?
« Reply #32 on: February 07, 2012, 02:39:46 AM »
I am self employed, mainly repairs to fishing boats, do welding (Stick, Mig, Tig) Milling, Turning and general spanner work. Used to be a fisherman myself until I got tired of being thrown about and soaked with freezing water 7 days a week ;D
« Reply #33 on: February 07, 2012, 12:47:45 PM »
Cool. I used to work with a diemaker who is now self employed in Michigan working on boats. Mostly sailboats.
« Reply #34 on: February 08, 2012, 07:38:34 AM »
The guy that sells the dugongs said they don't actually have adjustments. Just gonna start tuning servos again and cross my fingers.
« Reply #35 on: February 08, 2012, 10:57:51 AM »
If u pull hair out, does it grow back? I retuned my servos.  I believe them to now be correct. But now im getting zero motion from mach3. ????????????
« Reply #36 on: February 08, 2012, 12:59:57 PM »
Afraid I dont know anything about the Dugongs setup but kind of sounds like you may be in tuning mode which only accepts commands from a tuning programme?
« Reply #37 on: February 08, 2012, 02:20:42 PM »
I was able to get movement before I came to work. The tuning looked good but was too weak to push servos I guess. I went in and raised all the numbers and got the graph looking ok again. Still not travelling correct distance at 20000 and 22222.222. Getting a little discouraged but going to fight with it again tomorrow
« Reply #38 on: February 08, 2012, 02:45:56 PM »
How much out is it?
« Reply #39 on: February 08, 2012, 02:53:35 PM »
Not 100% sure. Today I zeroed over a dot I have in the center of my material. I let it run an engraving program with z raised up. When it returned to zero at the end of the program ( which had many direction changes ) it was off to the left and down over. 500 each way. Going to use dial indicator tomorrow
