Hello
Guest
it is
September 29, 2026, 04:45:31 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
VB and the development of wizards
How to add new hotkey?
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: How to add new hotkey? (Read 9150 times)
v tec
31
on:
January 24, 2012, 01:26:35 AM »
Hi how to add hot key for modify the speed rate with the keyboard?
Chaoticone
5,624
Precision Chaos
Re: How to add new hotkey?
Reply #1 on:
January 24, 2012, 05:19:58 PM »
The defalut 1024 set has hot keys assigned already for feed rate and spindle speed increase and decrease. What screen set are you useing?
If you could see the things I have in my head, you would be laughing too.
v tec
31
Reply #2 on:
January 25, 2012, 01:38:21 AM »
6 axis
v tec
31
Reply #3 on:
January 25, 2012, 01:48:22 AM »
Thanks and you know how to modify copycat wizard? For write the 6 axis in the g code
Chaoticone
5,624
Precision Chaos
Reply #4 on:
January 25, 2012, 06:47:03 PM »
I haven't used the copy cat wizzard so I doubt I can help you there. To add the buttons you want open the standard 1024 set in Mach Screen and you can get the the information needed to add the buttons you want to your screen. Just be sure you dont assign hotkeys to the buttons you add that have already been assigned to other buttons in your screen. You can use MachScreen to edit your screen as well. Klaus has done a great job with MachScreen and has some tutors on his site to help get you started useing it. You will also download Machscreen from his site. Lots of information in the Screen development board too.
This is a link to Klaus's site.
http://www.kd-dietz.com/klausphp/index_eng.html
Print
Pages:
1
Go Up
« previous
next »
