Hello Guest it is November 13, 2026, 11:49:31 PM
Author Topic: How to add new hotkey?  (Read 9418 times)
Offline v tec
  •  31 31
« on: January 24, 2012, 01:26:35 AM »
Hi how to add hot key for modify the speed rate with the keyboard?
Re: How to add new hotkey?
« Reply #1 on: January 24, 2012, 05:19:58 PM »
The defalut 1024 set has hot keys assigned already for feed rate and spindle speed increase and decrease.  What screen set are you useing?
Offline v tec
  •  31 31
« Reply #2 on: January 25, 2012, 01:38:21 AM »
6 axis
Offline v tec
  •  31 31
« Reply #3 on: January 25, 2012, 01:48:22 AM »
Thanks and you know how to modify copycat wizard? For write the 6 axis in the g code
« Reply #4 on: January 25, 2012, 06:47:03 PM »
I haven't used the copy cat wizzard so I doubt I can help you there.  To add the buttons you want open the standard 1024 set in Mach Screen and you can get the the information needed to add the buttons you want to your screen.  Just be sure you dont assign hotkeys to the buttons you add that have already been assigned to other buttons in your screen.  You can use MachScreen to edit your screen as well.  Klaus has done a great job with MachScreen and has some tutors on his site to help get you started useing it.  You will also download Machscreen from his site.  Lots of information in the Screen development board too.
This is a link to Klaus's site.
http://www.kd-dietz.com/klausphp/index_eng.html
